CODE 9:cylinder position sensor.................is my dist.BAD?
my car throws a code 9 which is CYP,will i have to replace the distributor housing in order for my car to run right or is there some way else i could take to clear this problem...............................LMK!
Well I don't show any code 9 anywhere, don't know how you came up with that. However, there are two different CYP codes.
P1381 Intermitant interruption
P1382 No Signal
Most likely likely the distributor, but many things are possible.
P1382 No Signal
