my seafoam experience
Old Jul 28, 2006 | 08:58 AM
EG type GTR
Guest
Posts: n/a
Default my seafoam experience
i just seafoamed my car several minutes ago. it has the heart of a jdm 98 itr. we all know they usually come with "only" 30,000km but theres really no way in telling unless the engine came from a whole clip with the cluster.
anyways, i only put 1/3 the can through the brake booster and ill put the rest in the gas. it took several minutes to put it through the bb while being careful not to stall. my leg was getting cramped doing it.
anyways, i idle around 800-810, never going below 800. pulling the bb, the idle jumped to 1500. after connecting back the bb, idle didnt change and stayed 800-810.
i waited 15 min and turned the car back on. it didnt smoke while i was sucking in the seafoam. it only smoked around 10-15 sec after turning the car back on. as i started to pull away in 1st, i could feel the difference already. less hesitation like it did before. i guess the former jap owner took care of the engine because there was barely any smoke coming out.
ripping through the gears, it felt so much smoother and rev happy and it feels that idle is a bit smoother.
seafoam
Old Jul 28, 2006 | 09:00 AM
hialeahzbg's Avatar
do u have awrite up for this? im getting a jdm gsr swap and want to do this...
Old Jul 28, 2006 | 09:02 AM
EG type GTR
Guest
Posts: n/a
Default Re: (hialeahzbg)
theres plenty of writeups already. i just wanted to share my experience of using seafoam on my jdm 98 itr
Old Jul 28, 2006 | 09:06 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (EG type GTR)
Now go change your oil!!!
Old Jul 28, 2006 | 09:09 AM
EG type GTR
Guest
Posts: n/a
Default Re: (walker111)
i dont think i need to change my oil. i only put it through the brake booster.
and my oil is only 200mi old.
Old Jul 28, 2006 | 09:12 AM
cool guy name
So you never put any in the crank case?
Old Jul 28, 2006 | 09:16 AM
EG type GTR
Guest
Posts: n/a
no, ill save that when im ready for a oil change. only brake booster for now and it helped
Old Jul 28, 2006 | 09:17 AM
CRXtacy2006's Avatar
change your oil....seafoam is formulated to break down oil and deposits. i mean come on its like less thatn $20. You'll seee what im talking about when you drain it. itll be like water.
Old Jul 28, 2006 | 09:20 AM
cool guy name
Default Re: (CRXtacy2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXtacy2006 &raquo;</TD></TR><TR><TD CLASS="quote">change your oil....seafoam is formulated to break down oil and deposits. i mean come on its like less thatn $20. You'll seee what im talking about when you drain it. itll be like water.</TD></TR></TABLE>
He didnt put it in his oil yet.
Old Jul 28, 2006 | 09:27 AM
94eg!'s Avatar
#1 Super Guy
Loved
You should probably change your plugs because the liquid carbon usually fowls them up. I have also heard of other people having problems with their O2 sensor after seafoaming. One guys solution was to take the sensor out & dip the tip in liquid seafoam to clean it off. That may also work with your plugs if they are expensive ones.
I can say that I seafoamed my 89 CRX, and about a year & a half later my O2 sensor took a crap. At least it was a $25 1-wire unit. I read about the dip idea after I already replaced the sensor. May be something to look into if you start getting poor gas mileage though since 4-wire sensors are much more expensive...
Old Jul 28, 2006 | 09:32 AM
EG type GTR
Guest
Posts: n/a
Default Re: (94eg!)
i just checked and no o2 cel
ill check my plugs later after it cools off
Old Jul 28, 2006 | 09:59 AM
94eg!'s Avatar
#1 Super Guy
Loved
Here is the thread I was talking about...
https://honda-tech.com/zerothread?id=1590443
jaesun
Honda Civic (2006 - 2015)
16
Apr 24, 2012 06:51 AM
lovelove
Jan 28, 2010 12:06 PM
Extreez
Nov 15, 2007 05:18 PM
AznJohn33
Mar 4, 2004 05:09 PM
