Replacing axle... ran into alot of problems... please help, i have to get it in by tomorrow afternoo
Old Jul 28, 2006 | 02:01 AM
Ideal's Avatar
Default Replacing axle... ran into alot of problems... please help, i have to get it in by tomorrow afternoo
So my passenger side axle was making alot of sounds and was definately broken, so I went to autozone and had them order me the axle I needed. Here are the steps I took to get it out
Jacked up the car(98 lude base)
took off the tire
took off the axle nut
removed the castle nut undrerneath the lower balljoint
broke off the balljoint
removed the through pin on the lower fork
pulled the broken axle out.
compared it to the new one, looked about the same dimensions, the new one had an extra cv joint rubber flap on both joints, but I didnt think much of it (should they look EXACTLY the same?)
I slid the new axle between the strut and fork, which was difenately a pain in the *** since I could just move the strut to the side like in my accord(which I found odd) and got it to go in easy, now reassembely, I decided to tighten the balljoint first, but no matter how hard I tried I just could not get it to get where it belonged, the closest I could get it was about a 1/4 inch away from where it belonged, tried everything I could to get it in and I couldnt....
what am I missing here guys should I have lostened or removed something else? Ive only done axles in my accord, but it was just about the same, something different from a 96 accord to a 98 lude?
This car is also a Manual Tranny, any extra steps or something? help!
Something msut be missing... please, please please help!
-Jon
Modified by Ideal at 3:15 AM 7/28/2006
Old Jul 28, 2006 | 03:08 AM
pentaq's Avatar
have you slid the axle through the knuckle yet? You should do this first and thighten an axle nut a bit and then try to tighten the lower balljoint.
Old Jul 28, 2006 | 05:44 AM
Finest's Avatar
Default Re: Replacing axle... ran into alot of problems... please help, i have to get it in by tomorrow afte
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ideal &raquo;</TD></TR><TR><TD CLASS="quote">compared it to the new one, looked about the same dimensions, the new one had an extra cv joint rubber flap on both joints, but I didnt think much of it (should they look EXACTLY the same?)
Got a picture?
Make sure the axle is fully seated into the transmission. Then check the hub side if it's sitting flush.
Otherwise, you probably got the wrong axle.
Old Jul 29, 2006 | 04:55 PM
Ideal's Avatar
I had to remove the dampner fork! damn!
Old Jul 29, 2006 | 05:40 PM
SKDRCR's Avatar
Default Re: (Ideal)
you should have removed the inner bolt on the lca.
you can move everything around easier that way.
you don't even have to disconnect the lca from the knuckle
mcdonoughEk00
Transmission & Drivetrain
Jul 18, 2014 07:49 PM
otgarza
Dec 4, 2012 08:55 PM
grjr
Aug 23, 2012 04:12 PM
Chee_dog
Jul 24, 2007 09:14 AM
Feb 19, 2004 08:54 PM
