Oil you guys use?
Old Apr 23, 2002 | 01:16 AM
Integraholic's Avatar
Default Oil you guys use?
Hey, what oil do all of you run? I personally run Mobil 1 full synthetic 0w 30
Old Apr 23, 2002 | 01:28 AM
iH8RICERZ's Avatar
Default Re: Oil you guys use? (Integraholic)
castrol gtx hard drive 5w30
Old Apr 23, 2002 | 03:19 AM
Dirt's Avatar
Default Re: Oil you guys use? (*****GotRice)
I started off using Castrol GTX 5w30, then switched to Mobil1 5w30 at 85k miles, and soon (as in next oil change) I'll be switching to Amsoil 10w30.
Old Apr 23, 2002 | 04:39 AM
ILUVTEC's Avatar
Default Re: Oil you guys use? (MmmVTEC)
I use castrol GTX 10w30
Old Apr 23, 2002 | 04:58 AM
M0NEYnH0s's Avatar
Default Re: Oil you guys use? (ILUVTEC)
castrol syntec 5w-30
Old Apr 23, 2002 | 05:28 AM
Ohlias's Avatar
Default Re: Oil you guys use? (m0neynh0s)
Pennzoil Full Sythetic....
Old Apr 23, 2002 | 05:44 AM
hybridreams's Avatar
Default Re: Oil you guys use? (Ohlias)
Mobil 1 5W-30 Synthetic
Old Apr 23, 2002 | 05:56 AM
StyleTEG's Avatar
Default Re: Oil you guys use? (hybridreams)
Amsoil 5w30 synthetic
Old Apr 23, 2002 | 06:24 AM
jrsccivic's Avatar
Default Re: Oil you guys use? (StyleTEG)
Mobile 1 5/30
Old Apr 23, 2002 | 06:27 AM
Rory Breaker's Avatar
Default Re: Oil you guys use? (jrsccivic)
Mobil1 10w/30
Old Apr 23, 2002 | 07:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
0w30? man that must be like water. I'm on Mobil 1 synth. 5w30 right now, but I will probably switch to 10w30 this weekend. In the future I may end up just going w/ Valvoline Max Life.
Old Apr 23, 2002 | 07:42 AM
scribnits's Avatar
Default Re: Oil you guys use? (PatrickGSR94)
5w30, Castrol GTX drive hard
Old Apr 23, 2002 | 08:01 AM
JohnnyK's Avatar
Valvoline SynPower Full Synthetic 5w-30
Old Apr 23, 2002 | 08:13 AM
fujitsuten's Avatar
Default Re: Oil you guys use? (JohnnyK)
AMS full synthetic
Old Apr 23, 2002 | 09:10 AM
SIK IN DA HED's Avatar
New User
Default Re: Oil you guys use? (fujitsuten)
Valvoline 10w30
Old Apr 23, 2002 | 09:41 AM
jeebusm3's Avatar
Default Re: Oil you guys use? (dlplayboy)
redline synthetic 5w30
Old Apr 23, 2002 | 09:42 AM
brwnrice's Avatar
Default Re: Oil you guys use? (gtravsr)
castrol syntec 5w 30
Old Apr 23, 2002 | 09:48 AM
Default Re: Oil you guys use? (brwnrice)
Well, all of my friends and I run 0w 30 because it is thin. When you start it up, it pumps easily and give you instant oil pressure. Also, oil is resistance to the crank trying to turn. So least resistance is more HP. Well, my theory anyway.
Old Apr 23, 2002 | 10:15 AM
ALF's Avatar
ALF
I ran (in order):
5W-30 Valvoline
5W-30 Pennzoil Synthetic Blend
5W-30 Mobil1
5W-30 Valvoline Max Life
I've been using Max life for the past 15k+ miles. Supposedly, the formula conditions seals to slow down wear and tear. Mobil1 was nice, but I could not keep up with the costs.
Here's an informative thread on oil: https://honda-tech.com/zerothread?id=163845
Old Apr 23, 2002 | 10:16 AM
Hapa DC5's Avatar
quaker state 5w30 full sythetic, hey it's free
Old Apr 23, 2002 | 12:37 PM
team intensity's Avatar
Default Re: Oil you guys use? (NemesisGSR)
i use 40 vavaline full race oil
Old Apr 23, 2002 | 01:12 PM
Community Builder
Default Re: Oil you guys use? (team intensity)
in a race car?
Old Apr 23, 2002 | 02:01 PM
Fooser's Avatar
I'm running with Amsoil 0 w30
Havent lost or burnt off any oil for over 4k so far. suppost to be good for at least 30,000 miles or one year. I dont think I can wait that long tho to change it. my thoughts are the washer might go bad. so I should change it anyways.
For $8-$10 a quart it better be good.
Old Apr 23, 2002 | 02:09 PM
Jesse H's Avatar
Mobil 1 5w30...trying Royal Purple next time around.
Old Apr 23, 2002 | 03:15 PM
ocbeta's Avatar
There is a special valve in the oil filter to prevent "dry" starts.
I have 128k on a 93 Integra LS, I run Mobil 1 Full-Syn 10w30
For some reason olive oil didn't work to well, I thought at least I could lower my cars cholesterol level.....
