car keeps dying?..
Old Jul 27, 2006 | 07:53 PM
JDMtype Eg6's Avatar
Default car keeps dying?..
my car started acting up today when i started it up. once i turned on my headlights my car died on me. Then it wouldnt even go on the on position.. my car was completely dead. after a few minutes i started it up again and drove it around the block and when i went to neutral to stop it died again. any help would greatly be appreciated.
Old Jul 27, 2006 | 10:12 PM
also i painted my cluster bulbs red today with transparent paint. could i have a short out in the cluster that would cause this? thanks..
forgot to mention my starter would grind and make my car hesitate at startup sometimes. would a fouled out starter cause me to have absolutely no power? thanks again for any help.
Modified by JDMtype Eg6 at 11:35 PM 7/27/2006
Old Jul 28, 2006 | 03:06 AM
civicstar's Avatar
Default Re: (JDMtype Eg6)
most of the time, that happens theres a problem with the alternator. when it hesitates, usually the power is not recharging.
Old Jul 28, 2006 | 06:54 AM
zacritz929's Avatar
Something with the alt, battery or starter went out or you have a bad ground.
Old Jul 28, 2006 | 01:59 PM
Default Re: (zacritz929)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zacritz929 &raquo;</TD></TR><TR><TD CLASS="quote">Something with the alt, battery or starter went out or you have a bad ground.</TD></TR></TABLE>
yea it was a bad ground from the battery to the engine bay ground. i cleaned the dirt off and i sanded the paint down to metal so the ground would be good. thanks for all the replies
patrickstar
12
Jan 12, 2009 05:22 PM
stiffinEK
Mar 4, 2008 09:55 PM
ShakesTheKlown
Jul 1, 2003 02:05 PM
jdmcivicek
Mar 10, 2003 01:52 PM
