95 prelude... slick size
Old Jul 27, 2006 | 07:13 PM
DarkBB4's Avatar
Default 95 prelude... slick size
hey well i just aquired a set of slicks from my brother
size is 20x6x14
and i have steelies from a 1991 accord... So i was planning on running them at the track tommorrow?
they should work alright right? (might not be the BEST for performance, but better than my nitto 450s!)
what psi should i run?
2nd gear burn out or 1st? for how long! (any write up's for how to run at the track on slicks)
Old Jul 27, 2006 | 10:54 PM
Rosko's Avatar
Default Re: 95 prelude... slick size (DarkBB4)
20 is small, but should help shorten up the gearing. Would be cool too see some good before and after runs on how much it lowers your e.t.
As long as the caliper/brakes clear the wheel then I wouldnt think there would be a problem, but I know theyre pretty close anyways.
Old Jul 28, 2006 | 07:25 AM
DarkBB4's Avatar
Default Re: 95 prelude... slick size (Rosko)
sounds cool!i hope i have ground clearance (
Old Jul 28, 2006 | 01:43 PM
DarkBB4's Avatar
dont clear brakes damnit!
Old Jul 28, 2006 | 03:13 PM
Rosko's Avatar
damn, I guess you'll just have to go without brakes, lol
Old Jul 28, 2006 | 04:45 PM
DarkBB4's Avatar
do 14" wheels clear calipers w/ 1/4" spacer?
Old Jul 31, 2006 | 01:47 PM
DarkBB4's Avatar
CAN YOU RUN 14" wheels iwth VTEC brakes?
Old Jul 31, 2006 | 03:17 PM
v4lu3s's Avatar
RTFM
afaik no stock 14 will fit over vtec brakes.
the accord wagon has the same caliper and it uses a 15 inch spare even though most other accords often came with 14 inch wheels...
ZCHondaCRX91
Aug 25, 2011 12:08 PM
Veris
Nov 3, 2004 12:53 PM
caLiH22A
Jun 16, 2004 12:12 PM
TurboJesse
Jan 9, 2004 12:07 AM
