1999 Accord Lowered S-Techs...Will I NEED a Camber Kit?
Old Jul 27, 2006 | 02:25 PM
ykwak's Avatar
Default 1999 Accord Lowered S-Techs...Will I NEED a Camber Kit?
Hello all,
lowered my car with s-techs for 1.7" drop in the rear, and a 1.8" drop in the front.
anyone know if a standard alignment on stock control arms can fix the negative camber with the lowered rear or front?
Or, will I need to get a camber kit.
Also, does anyone have an FAQ on using washers / etc to push the camber out a bit as an alternative to getting a kit?
thanks...just looking for fellow 6g owners with experience.
Old Jul 27, 2006 | 02:55 PM
YeuEmMaiMai's Avatar
Default Re: 1999 Accord Lowered S-Techs...Will I NEED a Camber Kit? (ykwak)
get the kit so you car can be correctly alligned.
Old Jul 27, 2006 | 10:11 PM
MasterShake's Avatar
i would recomend it but not nessacary
Old Jul 27, 2006 | 10:19 PM
philadd's Avatar
Default Re: (MasterShake)
The rear tires on 6th gens like to camber quickly when lowering the car. I have the same drop (with Neuspeed Sports), and my rear camber was around -2.5 degrees before installing the rear camber kit, which, btw, I already had purchased. The front will sit at about -1.0 degree w/o a camber kit, give or take .2 degrees, assuming that you don't have any bent/damaged suspension parts. This is within factory specs...
I would say to get just the rear kit. The front would be at your discretion.
Old Jul 28, 2006 | 01:16 AM
Tho's Avatar
Tho
I got this problem also how can I. cause my country doesn't have any store to sell kinds of camber kit. In case I would like to buy it from US how much is it (excluded transportation cost)
Old Jul 28, 2006 | 08:54 AM
philadd's Avatar
Default Re: (Tho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tho &raquo;</TD></TR><TR><TD CLASS="quote">I got this problem also how can I. cause my country doesn't have any store to sell kinds of camber kit. In case I would like to buy it from US how much is it (excluded transportation cost)</TD></TR></TABLE>
You can usually find rear camber kits for about 100 US dollars, not including shipping charges. Front camber kits can range anywhere from 100 to 250 US dollars, depending on the type of kit that you get.
fafsa
Apr 6, 2005 03:40 PM
94RedEGCoupe
Jul 4, 2004 08:33 PM
es_squared
Apr 3, 2004 02:04 AM
Eye TrIcKy AcCoRD
Oct 9, 2002 05:00 PM
Takeoff
Aug 11, 2002 01:08 PM
