Stock CD7 sway bar sizes
I'm looking to buy some urethane sway bar bushings, and wasn't sure which size the sway bars are on my accord. I have a 96 ex coupe.
Would it be 25mm front and 15mm in the rear?
Thanks!
Modified by oblivionlost at 7:12 PM 7/27/2006
Thanks!
check http://www.hondaautomotiveparts.com should tell you there.
So the front bar is 27mm? http://tinyurl.com/gh7t8
The rear is 15mm as expected: http://tinyurl.com/gmne2
Thanks for the heads up, I honestly didn't expect Majestic to list the size. They usually make is as ambiguous as possible to figure out what part you're buying.
I'm gonna go ahead and guess that the front is in fact 25mm thick. Reason being is that both Prothane and ES show a maximum of 25mm for the stock accord:
http://tinyurl.com/qrzoe
http://www.energysuspension.com/pages/hon1.html
If you know for sure that the front is in fact 27mm on a 5th Gen EX please let me know so I can cancel my order.
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oblivionlost »</TD></TR><TR><TD CLASS="quote">
Thanks.</TD></TR></TABLE>
it is 27 mm
edit: I just looked at your link and the 25 mm is probably the correct bushing for the front.
it is 27 mm
