help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!!
Old Jul 27, 2006 | 12:06 PM
si90rex's Avatar
Default help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!!
ok we just finished an ls vtec for a 88 hatch. nice built
skunk2
throttle body 68mm
intake manifold
stage 2 cams
cam gears
springs and retainers
_______________
gasket match ports
ITR pistons
now it idles at 4000! there are no vaccum hose hooked up but there no places for them onthe tb and intake man, what do we do. its not tuned yet but we can't get the idle down blow 2000! even when its warm.
pleaseeee help!
Old Jul 27, 2006 | 12:22 PM
Suck my DX's Avatar
Default Re: help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!! (si90rex)
sounds like a im gasket leak
Old Jul 27, 2006 | 12:27 PM
si90rex's Avatar
Default Re: help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!! (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a im gasket leak</TD></TR></TABLE>
ding ding ding what do we have for him jonny!lol
ya the head gasket is leaking on the exhaust side just below the dizzy. oil tho. but were not burning oil and coolant isn't mixing with oil either its a golden eagle head gasket. so u think replace head gasket.
thanks
Old Jul 27, 2006 | 03:52 PM
Suck my DX's Avatar
i said im gasket not head gasket...have u tried adjusting the throttle cable...mayb ur tps is fizucked
Old Jul 27, 2006 | 04:22 PM
SIXTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">
thanks</TD></TR></TABLE>
did you plug the original oil feed hole on the bottom of the head?
Old Jul 27, 2006 | 04:54 PM
si90rex's Avatar
Default Re: help!!!!!!!!!!!! ls/vtec done Idle @ 4000!!!!! (sixty-seven point six)
ya its pluged we fixed the idle at least it down to 900 thanks we still have a head gasket to replace
Old Jul 27, 2006 | 05:38 PM
SIXTY's Avatar
good luck
Old Jul 27, 2006 | 10:02 PM
Suck my DX's Avatar
so what was wrong with it?
Old Jul 28, 2006 | 05:27 AM
si90rex's Avatar
combo of the throttle cable being alittle tight, and the tps change and throttle plate adjusted.
the best throttle response i have ever seen.just tough the gas and it spikes. but were using a vafc for the vtec and running a ls ecu so we still need to fix the feul because it seems that the vtec is just bearly pulling when it kicks in we never messed with a VAFC so it will take some time to figure it out. going to the dyno in 2 weeks and we'll see what numbers we can push. hoping for 220+hp all motor.
hopfully higher.
DerekHollister
Apr 7, 2016 09:50 AM
Jonathan91891
Nov 15, 2015 04:13 PM
Mugen Type R
Feb 17, 2010 06:45 PM
skater5067
Apr 22, 2005 08:24 AM
Jammersplace
Sep 12, 2004 04:50 AM
