alrite here's the deal...
1990 honda civic wagon.
b16a2 w/ y1.
has been a disaster for the past 2 weeks.
at 2500 to 3000 rpms the motor can not accelerate at all. but it will idle. the motor does not cut out. already completely replaced the distributor, problem is still not fixed. it threw a code 7? any suggestions would be great, thanks.
b16a2 w/ y1.
usually jumpy tach is a sure the ignitor is done, but since you just replaced the dizzy, was it a new piece?
was the car fine before this, or did you just do your swap?
are you running obd1? what ecu?
80 dolla crx hf
Mar 2, 2010 08:55 AM
