I need help getting my JDM Headlights one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow blur »</TD></TR><TR><TD CLASS="quote">Bend it, remove the AC or order a JDM AC line.
JDM lines go from the RH side to the firewall. That won't work.
You just have to bent it. It is ok to bend it. Just use firm pressure and do it slowly. What you don't want is a kink so make large radius bends. It is easier than you think.
</TD></TR></TABLE>JDM lines go from the RH side to the firewall. That won't work.
yea i bent mines and it kink and leaked all of my ac ****...so i had to find a professional aluminum welder to patch up the kink and refill my ac...so becareful
when u do it...
when u do it...
I just removed my A/C
mostly because it would cost too much to get it working again
which then gave me an excuse to install the jdm hid headlights
..... or.... was it the other way around?.....
