another shift linkage question
Old Jul 27, 2006 | 01:36 AM
94VXLSHatchie's Avatar
Default another shift linkage question
ok so i have a B20 with a B16 tranny and a GSR linkage, and it wont go into reverse and 5th, i checked on my friends car who has a B16 tranny also and his has a bushing looking thing on the shaft coming out of the tranny, and my shift lever has a lot of play in it, u can do a full circle jsut moving it around...can i get a bushing for the shaft or something so it wont have play and it can go into the gears?
Old Jul 27, 2006 | 06:44 PM
Default Re: another shift linkage question (89crxsohcvtec)
bump.
anyone?
Old Jul 27, 2006 | 06:47 PM
JDMlyfestyle's Avatar
Helps to know what car your Using.. If it is the 89 CRX then the EF forum would be more help
Old Jul 27, 2006 | 07:30 PM
Default Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Helps to know what car your Using.. If it is the 89 CRX then the EF forum would be more help</TD></TR></TABLE>
no its not on the crx, its on a 92 civic hatch
Old Jul 27, 2006 | 07:40 PM
garyc17's Avatar
Default Re: (89crxsohcvtec)
Change all the bottom bushings of your shift lever(the one going into the car). Replace the entire linkage that connects to that lever. Get a new pin that locks this linkage to the tranny. You will be good to go then.
Old Jul 27, 2006 | 07:58 PM
Default Re: (garyc17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Change all the bottom bushings of your shift lever(the one going into the car). Replace the entire linkage that connects to that lever. Get a new pin that locks this linkage to the tranny. You will be good to go then.</TD></TR></TABLE>
thanks for the input....all those bushing u mentioned are good, but i saw that on the tranny itself theres like a little rod coming out where the linake goes to, and it has a hole to put the pin in, well i checked on my buddies LS tranny and on his, theres a bushing on that rod, mine doesnt have that, could that be wahts causing the problem? if so, can i buy that bushing and put it on?
akshn1
Aug 5, 2009 04:31 AM
ERKK
Apr 28, 2009 05:31 PM
CarAudioPro
Dec 20, 2006 07:53 PM
jdmEF8racer
Mar 30, 2006 04:17 PM
evilsolb16
Sep 25, 2004 09:24 PM
