clarification please
ok, i can't seem to get this straight-
i know 90-93 integra axles fit a zc transmission. but what hubs do they fit?
si axles are NOT the same as std. axles, yeah? if not, what are the differences? and which axles fit in a std. hub? and for that matter, how do you go about swapping hubs? Do you have to replace the whole steering knuckle assembly? thanks for the info everyone.
I know they'll fit 93 civic hubs. not sure if they fit 88-91 or not. the only hubs different in that year that I've found is the hf-std hubs. all the others are the same, but I think the 92 up axles use bigger seals where it goes into the hub.
