How can you test INNER cv joints
Old Jul 26, 2006 | 10:37 PM
JDM H22's Avatar
Default How can you test INNER cv joints
My Driveshaft shop axel had a bad OUTER cv joint that clicked really bad so I ordered a new outer joint from Driveshaft Shop. After racing at the track, on my way home I noticed the car would shake under throttle. I figured that joint **** the bed. So I replaced it. It still shakes under throttle. Something else let go. I am replacing the tie rod bushings, and not that I think it is this, but also the upper ball joints. I also will check the rear motor mount since I havent check that one yet. It seems to me that it is drivetrain though. The only thing left is those inner joints. I dont want to replace them till I know they are bad, so is there any way to check or know if they are bad. thanks
Old Jul 28, 2006 | 08:15 AM
JDM H22's Avatar
Default Re: How can you test INNER cv joints (JDM H22)
Driverside has very little play and passenger has a little more. WTF
Old Jul 28, 2006 | 09:04 AM
Slopoke's Avatar
Im willing to bet its the inner cv joint. Vibration under acceleration is a tell tale sign of an inner cv joint.
The only real way to tell is to pull the axle out, and pull the joint apart.
I've had to do this before.
I had both axles out and I still couldnt figure out which one was bad until I pulled the boots off and the joints apart.
b20bFourDoorCivicLX
Dec 17, 2013 05:22 PM
JDM H22
Aug 3, 2006 10:02 PM
JDM H22
Jul 28, 2006 08:16 AM
JDM H22
Suspension & Brakes
Jul 27, 2006 11:58 AM
jdmh22luda
Aug 10, 2005 03:21 AM
