How can you test bad inner cv joints
Old Jul 26, 2006 | 10:35 PM
JDM H22's Avatar
Default How can you test bad inner cv joints
My Driveshaft shop axel had a bad OUTER cv joint that clicked really bad so I ordered a new outer joint from Driveshaft Shop. After racing at the track, on my way home I noticed the car would shake under throttle. I figured that joint **** the bed. So I replaced it. It still shakes under throttle. Something else let go. I am replacing the tie rod bushings, and not that I think it is this, but also the upper ball joints. I also will check the rear motor mount since I havent check that one yet. It seems to me that it is drivetrain though. The only thing left is those inner joints. I dont want to replace them till I know they are bad, so is there any way to check or know if they are bad. thanks
Old Jul 27, 2006 | 04:46 AM
BDRphaSe2's Avatar
check motor mounts similar shakes happened with me and i had a bad axle as well fixed it wasent the shaking, checked mounts all fine, it was my struts, so i got new struts and no more shake
Old Jul 27, 2006 | 10:56 AM
JDM H22's Avatar
Default Re: (BDRphaSe2)
blew a coilover and I have the damper too replace it, but do you really think that could cause it.
Old Jul 28, 2006 | 08:16 AM
JDM H22's Avatar
Default Re: (JDM H22)
think it could be the rack
Dwight Schrute
Suspension & Brakes
Aug 26, 2006 11:15 AM
JDM H22
Aug 3, 2006 10:02 PM
JDM H22
Jul 28, 2006 09:04 AM
JDM H22
Suspension & Brakes
Jul 27, 2006 11:58 AM
havalilsi
Suspension & Brakes
Apr 13, 2005 07:33 PM
