Anyone know the injector size/type for accord type-r (obd2) injectors?
Like it says, does anyone know the size or even type (peak/hold or saturated) of these injectors? They dont look like regular honda injectors, they are much narrower, black, and are pointed on the manifold side (like the spoon ones if you've ever seen them) I picked up a set but dont quite know what to do with them, thanks.
[Modified by sohckid, 11:39 PM 4/22/2002]
that would be tough to find out...chances are they are similar to prelude vtec injectors...and OBD2 H22 injectors are saturated...but you can always have them flow tested
obd-II h22 injectors are 270 cc/min
forget finding stock 'R' b/s and just get a set of rc injectors,
I am unsure if a OBD-II ecu will correct for injector size as an OBD-I ecu will
plus unless your getting stock replacements there is no need to get larger injectors what have you done to be running close to 100% duty cycle?
Its not really like that, I'm running a turbo w/450 inj. but these accord type-r injectors are just sitting around collecting dust, they are from my friends accord type-r swap (yes thats right a real one), they didnt work right with his ecu so we just swapped in some prelude ones, but I dont know that to do with these.
.ad.
.ad.
cyrix12
Dec 30, 2005 05:19 PM
therealnapster
May 12, 2002 12:36 AM
