HELP!!! 00 SI Turbo
Old Jul 26, 2006 | 06:31 PM
raresi99's Avatar
Default HELP!!! 00 SI Turbo
I was driving today and car just shut off.. Went to restart and just clicked. So I went and got my jump box and the car started to crank with jump box. Well thats all it does is crank. Fuel pressure gauge reading 60 psi while cranking. Check engine light does not come on cause I am running AEM EMI. The aem gauge is not showing any codes when ignition is on. It just cranks and cranks acting like its not getting fuel. Anyone have any ideas before I go to work tomorrow and start replacing ****.??
Old Jul 26, 2006 | 07:32 PM
raresi99's Avatar
Default Re: HELP!!! 00 SI Turbo (raresi99)
anyone????
Old Jul 27, 2006 | 04:55 AM
Dueceification's Avatar
Check ur spark
Old Jul 27, 2006 | 09:09 AM
spoolbyeyou's Avatar
Default Re: HELP!!! 00 SI Turbo (93b16hatch)
i have a 00 turbo si too and mine use to be driving then all of a sudden shut off...it would crank just like you xplained but not start until like a hour later, come to find out it was a loose spark plug grounding out the distributor so your best guess is to check there and the ecu wiring.
Old Jul 27, 2006 | 01:55 PM
raresi99's Avatar
Default Re: HELP!!! 00 SI Turbo (spoolbyeyou)
Thanks guys I after 2 hours of checking this and checking that.. Had no spark from distributor. Was about to order a new one when I started to remove the distributor and pulled on my msd wire going to the neg battery terminal and found it not connected. connected it and the damn thing started right up.
Glad it was nothing serious.. Thanks for the help
dubsker
Aug 12, 2008 10:02 PM
Ls_V_TurboSi
Feb 2, 2006 08:53 AM
Tony Ignatz
10
Sep 21, 2004 07:17 PM
btrim23
Apr 24, 2004 04:52 PM
neof69
Jan 12, 2003 06:10 PM
