problem with vtec
Old Jul 26, 2006 | 06:18 PM
1_SC_GSR's Avatar
Default problem with vtec
i have a obd0 b16 in 89 dx crx,my mod are the i/h/e,skunk 2 pro series i/m,pr3 ecu,and apexi 2 VAFC,problem is when punch it ,vtec seem to be langing,my vtec hits at 4700,i keep speeding threw 1 and 2 gear untill the end of second it start to pull hard,then the vtec does hit hard threw all the gears, then when i turn off the car and turn it on again starts all over again. Can anybody help me with this?
Thanks
Old Jul 26, 2006 | 06:27 PM
streetmodified's Avatar
vtec hits at 4700? ... did you change that with your vafc? that doesnt really make sense to me. I thought most vtec motors switched over in the 5k range. (my ITR motor changes over at 5700rpm).
maybe you could try switching your vtec point back over. for most people, all you really need is to have vtec hit right where your redline upshifts land (on an itr motor, thats 5700 rpm). that way, you're in vtec throughout a WOT run, shifting at redline. the only real advantage you'd get from lowering your vtec crossover is 1) you're in vtec earlier in 1st gear, before your first shift. however, lowering vtec too much would cause an undesirable condition with too much valve overlap down low. this would cause your engine to "lag"
just a thought. its hard to say without riding in the car. but your crossover point sounds low. i dont know the spec... but maybe someone else can chime in.
Old Jul 26, 2006 | 07:23 PM
ok, i just checked... and (i hope this is correct) ... i think B16s are supposed to cross over at 5200 rpm. but sometimes the tachometer doesnt read correctly after the swap. If you're reading the switchover from your vafc, then you have a problem.
Old Jul 27, 2006 | 03:02 PM
1_SC_GSR's Avatar
Default Re: (streetmodified)
when i swap the b16 into the crx the vtec hit at 4400,and i put the vafc so i can
hit vtec higher at 4700,i did all of this more then a year ago, and the lag start about 2 to 3 mouht ago,thanks
Old Jul 27, 2006 | 03:08 PM
y-49's Avatar
i think b16s vtec crossover is 4800 stock but not absolutly sure. i would get rid of the vafc. and if u wanna tune it get crome or turboedit
Old Jul 27, 2006 | 04:11 PM
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetmodified &raquo;</TD></TR><TR><TD CLASS="quote">ok, i just checked... and (i hope this is correct) ... i think B16s are supposed to cross over at 5200 rpm. but sometimes the tachometer doesnt read correctly after the swap. If you're reading the switchover from your vafc, then you have a problem.</TD></TR></TABLE>
pr3 and pw0 differ slightly (about 400rpm) in the vtec crossover point.
5400 and 5800 respectivley, IIRC.
Old Jul 27, 2006 | 06:28 PM
thanks for the correction. i can only speak to the B18C with confidence and im ok with that
Old Jul 27, 2006 | 07:27 PM
1_SC_GSR's Avatar
if i take the vafc off, the problem will go away???? need help!!!!!
Old Jul 27, 2006 | 08:20 PM
1_SC_GSR's Avatar
Default Re: (1_SC_GSR)
or could it be the oil pump???
BumbleBee Tuna
54
Jul 2, 2007 06:21 AM
xvracing
May 1, 2004 01:49 PM
civickid03
Mar 25, 2004 11:00 AM
