converting to odb1
Old Jul 26, 2006 | 03:59 PM
hbyrd8701's Avatar
Default converting to odb1
im going mahe this quick, i already have a p28 with the jumper harness, gsr dist with jumper harness, dsm 450 cc injectors because im going boost, do i need 4 wire o2 sensor or am i alright. also do i need anything else?
Old Jul 26, 2006 | 04:01 PM
civicandy's Avatar
Default Re: converting to odb1 (hbyrd8701)
you need 1 o2 sensor, 4 wire, down by the cat
Old Jul 26, 2006 | 04:09 PM
HondaFerris's Avatar
Default Re: converting to odb1 (civicandy)
I thought you can run without the 4 wire o2
Old Jul 26, 2006 | 04:20 PM
hbyrd8701's Avatar
ok im trying to understand, i have a unchip ecu but i have a uberdata software i cant have it program to read my o2 senser if not do i have to get odb1 o2 senser and how wire up the four wires, do i go to the junkyard to find it, or do i make my own wires by add four wires?
Old Jul 26, 2006 | 04:32 PM
hbyrd8701's Avatar
some one...................
Old Jul 26, 2006 | 04:37 PM
4thgenhtch's Avatar
your jumper has the four wires you need to run to the o2 sensor, Just cut the plug off the harness at the junkyard so that you can change out you sensor if needed
Old Jul 26, 2006 | 04:44 PM
hbyrd8701's Avatar
Default Re: converting to odb1 (4thgenhtch)
i didnt want to sound like a dumbass. i had most of the stuff for almost a year and a half, so i kind forgot. im finally getting my stuff together. thanks
Old Jul 27, 2006 | 04:47 AM
civicandy's Avatar
good luck
Old Jul 27, 2006 | 03:38 PM
91SiZ6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">you need 1 o2 sensor, 4 wire, down by the cat</TD></TR></TABLE>
Stock location on the #4 runner, either place works.
Old Jul 28, 2006 | 04:58 AM
civicandy's Avatar
Default Re: converting to odb1 (91SiZ6)
that i did not know. thanks
Hondamonster
12
Jun 21, 2007 08:19 PM
sol2hatch
Mar 2, 2006 04:10 PM
SI_Ro
Jan 12, 2004 06:43 AM
Turbo88hatch
Feb 16, 2003 09:21 AM
