Power steering add
You will need more than just that. You will need to the rack too. I would ask why in heavens name do you want to put PS on the car.
Manual Steering > PS Steering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old 2nr »</TD></TR><TR><TD CLASS="quote">A little hard steering to begin with. Add the weight of the new motor, and the fact that everything is open and easy now, why not.</TD></TR></TABLE>
Because it sucks. It adds weight and robs power, and isn't as responsive. I got a better solution, the benifits will be two fold. Buy a weight set and start lifting. Don't be such a puss. I used to run no PS on a Suzuki Samurai with welded diffs, and 35" tires. Then steering components broke and I had to upgrade. Not only will your car be faster and better handling, you will bw in better shape. PS sucks. The best car ever made didn't even have power steering.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart »</TD></TR><TR><TD CLASS="quote">
Because it sucks. It adds weight and robs power, and isn't as responsive. I got a better solution, the benifits will be two fold. Buy a weight set and start lifting. Don't be such a puss. I used to run no PS on a Suzuki Samurai with welded diffs, and 35" tires. Then steering components broke and I had to upgrade. Not only will your car be faster and better handling, you will bw in better shape. PS sucks. The best car ever made didn't even have power steering. </TD></TR></TABLE>X2
oneill1207r
Oct 14, 2024 03:30 PM
Black R
Nov 8, 2012 12:30 PM
rody084
11
Dec 7, 2003 01:07 PM
