EF Front Camber Kits
Hey - I have a Skunk2 EG / DC2 front camber kit here and am wondering if it will fit an EF Civic? I've looked on the Ingals web site to see if the EF and EG camber kits have the same part number but they don't list an ingals kit for EF Civic. Why did I look on Ingals? Well it doesn't matter the brand, if EF and EG part numbers were the same then it's the same for most (all?) other brands =]
Anyhow any help is appreciated!
nope you cannot...i dont know about the ingals though...
im useing ingals on both my 88 civics...its totally different than the skunk camber kit..thats why you cant interchange them
i had the ingalls kit on my old crx. it works ok but is basically impossible to adjust the camber, unless u have alot of time on your hands. i used it because it gave me much needed positive camber, but i never adjusted it. i think i had about -2 deg. with it. someone makes a ball joint that has adjustable camber, but i'm not sure. or you can get the vision upper arms for about $400
