Trailing Arm Bushing Removal
Old Jul 26, 2006 | 09:24 AM
Vitesse's Avatar
Default Trailing Arm Bushing Removal
Hey guy's .... so I bought a new Integra
For it to pass safety it needs the trailing arm bushings replaced, Originally the mechanic who safety inspected my car told me that I could not buy bushing by itself and that I need to buy two new arms (one for each side). But, he was sadly mistaken; I did infact find the bushings.
Now, the problem remains a constant annoyance. I don't have a press to take out the original bushing ( I thought of melting the rubber and hammering it out but I don't believe that's going to happen) or to replace the bushing with the new one.
As of now my option's to my understanding are: Take the arm's off myself, and have the dealer Re-install the new bushings given they have the proper press. (the tricky part is that the bushings themselves have notches on either side - one side only- so it's a serious variable to consider) They could, I'm assuming fab a press to work for it.
Black book on the arm removal/bushing install is 6.2 hrs @ 90$/hr cdn. So Fuvk that.
I have a general idea from my own provided knowledge and my friends; but from anyone who has undergone this task before some help would be greatfully appreciated. **Full insructions** or **helpfull hints**
Thanks guy's
p.s. it's the upper bushings
also I'll post pics later of the new bushings
Old Jul 26, 2006 | 09:46 AM
Vitesse's Avatar
Default Re: Trailing Arm Bushing Removal (Vitesse)
No one?! expletive!
Old Jul 26, 2006 | 10:10 AM
Mt3c's Avatar
https://honda-tech.com/zerothread?id=1589298
there is also a link in there somewhere, for the tool to purchase. I have the ebay users name, Mike something, but search for that tool on ebay. he might have one still in stock.
Old Jul 26, 2006 | 10:17 AM
BOOSTED RIVAL's Avatar
take off the trailing arm and take it to a machine shop to let them press it out, I did my that way and it only cost me 15 dallor a press so for both 30 dallor. Get a after maket like prothane or energy supension or go with stock one and just take it to a machine shop.
Old Jul 26, 2006 | 10:28 AM
Vitesse's Avatar
Default Re: Trailing Arm Bushing Removal (Mt3c)
two words man.
LIFE SAVER
Old Jul 26, 2006 | 10:31 AM
Vitesse's Avatar
Default Re: Trailing Arm Bushing Removal (BOOSTED RIVAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED RIVAL &raquo;</TD></TR><TR><TD CLASS="quote">take off the trailing arm and take it to a machine shop to let them press it out, I did my that way and it only cost me 15 dallor a press so for both 30 dallor. Get a after maket like prothane or energy supension or go with stock one and just take it to a machine shop.</TD></TR></TABLE>
I already have the prothane ones (red) I've heard they're not as good as OEM because The Prothane/ES bushings do not allow the right dimensions of travel; but other's ask for proof saying they did the install and things went fine. + Partsource rents out the tool!
Old Jul 26, 2006 | 11:24 AM
yeah I got the prothane trailing arm bushing too. Alot of people in here say it will blind the supension but I don't feel anything different but it is much stiffer then stock.
Old Jul 26, 2006 | 11:29 AM
Vitesse's Avatar
Hod did you do the install? ... the tool or a press?
Old Jul 26, 2006 | 11:33 AM
I take the part to a machine shop to press out the old one and they install my new one.
Old Jul 26, 2006 | 12:31 PM
Vitesse's Avatar
Any other input?? I don't think i'm using the press
Old Jul 27, 2006 | 09:02 AM
Vitesse's Avatar
bought it!!
Old Jul 31, 2006 | 10:51 PM
dohcgarage@714's Avatar
what you can do is melt the rubber part off and then if you have a sawzaw cut the sleeve out and then if you can put your other bushing in
Old Jul 31, 2006 | 11:09 PM
vinai's Avatar
Default Re: Trailing Arm Bushing Removal (dohcgarage@714)
Your still not going to be able to get the new bushing in. Definetly need a press.
Old Jul 31, 2006 | 11:48 PM
Noemotion_91DA's Avatar
Default Re: Trailing Arm Bushing Removal (vinai)
I had the same problem with my DA. So I removed the control arms and had a machine shop press the new ones on.
Old Aug 1, 2006 | 06:29 AM
My95SlvrBlt's Avatar
i had my lcas off the car and was able to hammer them out. I had no ride, and no press, so i made due. If your lowered, clock them by rotating a few degrees counterclockwise
Old Aug 1, 2006 | 06:37 AM
ragejed's Avatar
Default Re: (My95SlvrBlt)
Mugen makes the OEM Like replacements, get those and be done with! as for getting out the old ones....big ******* hammer...and to get the new ones in you ask? big ******* hammer. this is NOT rocket science...i did this before. the bushing change-out that is...not the rocket science thang...
Old Aug 1, 2006 | 06:43 AM
Default Re: (ragejed)
The honda OEM replacement(52385-sr3-000) = mugen replacements. They were redesigned. Acura actually had a diff bushing then honda, but age still takes a toll on them.
I think when I clocked mine, it was something like 15* Seemed that with being super low, and not so low, the bushing was very minimally changed. Seemed to be just the initial drop that kills these things.
Old Aug 1, 2006 | 07:46 AM
solid gsr's Avatar
you forgot to say big ******* hammer
Old Aug 1, 2006 | 08:12 AM
Well it was i think a 2-3lb hammer
PatrickGSR94
Suspension & Brakes
44
Jun 13, 2013 03:28 PM
DO-WORK-SON
Suspension & Brakes
15
Mar 16, 2013 07:10 PM
edogmb
Jul 7, 2012 04:15 AM
efyou999
Suspension & Brakes
10
May 28, 2010 09:12 AM
in1accord
Aug 31, 2007 04:32 AM
