after crowerII install idle sometimes has trouble catching itself when put in neutral.
Old Jul 26, 2006 | 06:59 AM
oranginal's Avatar
Default after crowerII install idle sometimes has trouble catching itself when put in neutral.
after crowerII install idle sometimes has time catching itself when put in neutral either at a stop or when i put it in neutral to coast on the highway.
i checked the vaccum lines and they are all in the right spot.
so i was wondering if any1 else had this problem because with these upgraded cams (they have the upgrades stock idle lobes as well if that matters.)
or if i should/need to adjust either my IACV (idle air control valve) or turn up the idle on the idle screw a little.
thanks
edit: i unpluges the IACV, turned the idle screw counter clockwise about 1.5 turn, tried to start the car to get a base idle but it would just stall, so i plugged the IACV back in and reset tyhe ecu(- cable off fore a few seconds)and it is fine now, does not even want to stall. after warming up idles around 800-820rpms
Modified by oranginal at 11:19 PM 7/26/2006
Old Jul 26, 2006 | 07:03 AM
98vtec's Avatar
moderator emeritus
Default Re: after crowerII install idle sometimes has trouble catching itself when put in neutral. (orangina
u need a REAL tune.
nuff said.
have you done the idle relearn process?
Old Jul 26, 2006 | 07:19 AM
oranginal's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
have you done the idle relearn process?</TD></TR></TABLE>
what is this? and do u think another tune would help this problem or just the overall horsepower?
thanks for all the replies u have been posting to my problems, i appreciate the help
Old Jul 26, 2006 | 07:54 AM
98vtec's Avatar
moderator emeritus
i real tune consists of idle tuning, part throttle tuning and WOT tuning.
a vafc is not a real tune.
Run Away
Mar 11, 2006 05:08 PM
