how much timing is thrown off from stock when a spoon 2 layer head gasket is installed ?
I got a 99 Gsr and I plan on putting a spoon 2 layer head gasket on to gain some compression. I hear by putting on a thinner head gasket it throws off the timing. If any one has done this upgrade, what degreeing of the cams did you set yours with?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">No it has nothing to do with timing, OEM is 3 layer, spoon is 2 layer slightly bumping up your compression.</TD></TR></TABLE>
This is true ^ Do you had any work done to your cars head...ie. pistons with higher compression or valve adjustment? If so then you might run into problems, but if it's stock I wouldn't worry about it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcMONSTER »</TD></TR><TR><TD CLASS="quote">No it has nothing to do with timing</TD></TR></TABLE>
lude98SH
Feb 8, 2007 08:49 AM
JDMvtecDRAGSTA
Mar 26, 2002 01:55 PM
