Honda Fit Honda Fit (Jazz)
So if I get a different pair of rims from some place, it will change the offset?
Old Jul 26, 2006 | 05:00 AM
nightshift's Avatar
Default So if I get a different pair of rims from some place, it will change the offset?
That is my question.
Old Jul 26, 2006 | 06:06 AM
ieldib's Avatar
Default Re: So if I get a different pair of rims from some place, it will change the offset? (nightshift)
For the one millionth time. Yes. Get something with a +38 offset, and you won't have issues. I also wouldn't go bigger then a 16x7. Anything bigger then that on a Fit would seem pointless.
Old Jul 26, 2006 | 09:35 AM
nightshift's Avatar
Default Re: So if I get a different pair of rims from some place, it will change the offset? (ieldib)
so what website sells rims and shows the offset? Will a 16"7.5 be too big?
Old Jul 26, 2006 | 10:08 AM
Fitfokker's Avatar
Are you a special needs person or what?
If you're gonna buy wheels for a car you need to know the bolt pattern and diameter and the offset. Most retailers can tell you what offset you need and provide you with spacers if needed. Check out tirerack.com
prejdmlude
Jul 16, 2008 09:50 PM
G_seven
Acura TSX
May 8, 2008 09:18 AM
civicVI
Acura TSX
Aug 19, 2007 10:28 AM
dtray187
Honda S2000
May 23, 2006 01:36 PM
VTECLuDe96
Dec 15, 2004 08:04 AM
