Da9 retrofit dc2 type r suspension question
Hey guys
I just scored a sweet 92 integra RS. I have a set of factory spring + shock combos with housing from a 2000 (DC2) Integra ITR.
Is it possible or if you know of... a way to fit that suspension onto the car?
I'm sorry if this has been brought up a million times but the search didn't return any successful results.
Thanks in Advance
Thanks in Advance
call me stupid but wont that throw the hole car off , i mean the weights not even the same . and they are stock parts.. whats so much better about them . just because they are type-r...
I think the spring rates are stiffer and i hear it will drop teh car 1/2 inch. If anything my rear shocks need to be replaced eventually and I was thinking about using them all the way around.
If I cannot use the housing, would it be recommendable to use springs and shocks on the car if they fit?
Thanks
Thanks
Head over to http://www.g2ic.com and do a search for the "elusive hybrid suspension guide." That should help you out a lot.
+.::*SLOW_EM1*::.+
Suspension & Brakes
Jun 29, 2011 11:15 AM
