throwing a CEL 17 VSS after fixing CEL 23 KNOCK and changing oil - speedo works what could this be?
Old Jul 25, 2006 | 08:39 PM
oranginal's Avatar
Default throwing a CEL 17 VSS after fixing CEL 23 KNOCK and changing oil - speedo works what could this be?
alright originally i was throwing a 23 (knock sensor) and a 20 (something with the inside fuse box)
at that time my car could only rev to 7400.
i replaced the knock sensor today and did an oil change as well and it was running fine, even put the rev limiter back to normal at 7800.
then i threw a CEL and put me in protective mode with a 6800 rev limiter throwing a CEL 17 VSS(vehicle speed sensor) and 23 (knock sensor)
since i just replaced the knock sensor i reset the ecu and now i am only getting the 17 VSS throwing me in limp mode at 6800 rev limiter. my speedo works fine, what else could cause this?
thanks to all who post for feedback
EDIT: FOUND ANSWER: I HAVE THE APEXI REV SPEED METER AND I GUESS WHEN I JUST HAD A NEW THERMOSTAT PUT IN THEY DISCONNECTED IT? NOT SURE Y BUT IT WASN'T CONNECTED.
Modified by oranginal at 10:55 AM 7/26/2006
H2b-eghatch
Aug 17, 2011 05:17 PM
garyc17
Dec 1, 2007 12:48 AM
outlawstar27
Jun 9, 2007 08:37 AM
djsire
Mar 26, 2007 06:29 AM
