How many ft lbs of torque for engine mount bolts?
Old Jul 25, 2006 | 03:01 PM
hu's Avatar
hu
Default How many ft lbs of torque for engine mount bolts?
My cousin has my Helms and he is on vacation. I put in innovative mounts. Does anybody know off hand how many foot pounds of torque you need to tighten the bolts, etc...
Thanks in advance for the help.
Old Jul 25, 2006 | 03:18 PM
Chuckles99SH's Avatar
Default Re: How many ft lbs of torque for engine mount bolts? (hu)
donno but somewhere I found a link on here to download the helms manual for preludes via PDF files.. hope that helps some.
-peaz
Old Jul 25, 2006 | 03:32 PM
xxmastermindxx's Avatar
Default Re: How many ft lbs of torque for engine mount bolts? (Chuckles99SH)
this is from the Chiltons manual on the Prelude, dont know if it'll help since it aint Helms
i'll just type it word for word, dont wanna miss a step
Tighten the engine mounting bolts in the following sequence:
a. Tighten the rear engine mount-to-frame bolts snug only
b. Tighten the rear engine mount through-bolt snug only
c. Tighten the rear engine mount through-bolt snug only
d. Tighten the side transaxle mount through-bolt snug only
e. Tighten the engine side mount through-bolt snug only
f. Tighten the side transaxle mount-to-block nuts to 28 ft. lbs.
g. Tighten the engine side mount-to-block bolt and nut to 40 ft. lbs.
h. Tighten the rear engine mount through-bolt to 47 ft. lbs.
i. Tighten the rear engine mount-to-frame bolts to 40 ft. lbs.
j. Tighten the front engine mount through-bolt to 47 ft. lbs.
k. Tighten the side transaxle mount through-bolt to 40 ft. lbs.
l. Tighten the engine side mount through-bolt to 40 ft. lbs.
then it says failure to follow that sequence results in excessive vibration and noise and wear yadda yadda
Old Jul 25, 2006 | 07:46 PM
asdfsad's Avatar
Default Re: How many ft lbs of torque for engine mount bolts? (xxmastermindxx)
You can dl Helm's from here
http://spoonhonda.com/index_ie.htm
You need to click download first then you can start.
And here are the chapters.
http://www.preludepower.com/fo...18949
Good luck!
Old Jul 25, 2006 | 09:57 PM
hu's Avatar
hu
Thanks for all of the help. I really appreciate it
gsm2sw
Oct 15, 2015 10:49 PM
ernbar
Honda Civic (2001 - 2005)
Sep 27, 2012 05:41 PM
pinoyboy204
May 18, 2006 11:02 AM
Voodooboy520
Aug 10, 2005 11:37 AM
vtecmike1
May 18, 2004 04:32 PM
