Jdm itr motor with ys1 cable trans forsale.
Old Jul 25, 2006 | 02:35 PM
jaydmcrx's Avatar
Default Jdm itr motor with ys1 cable trans forsale.
engine:
jdm itr long block
ctr cams
aebs intake mani
ported itr 70-65mm throttle body
jdm itr header
srr cam gears
outlaw engineering gasket kit
acl rod, main, thrust bearings
arp rod bolts
arp head studs
portflow valvesprings and retainers
baffled oil pan.
hondata s100
600 miles on the rebuilt motor.
transmission/drivetrain:
jdm b16 ys1 trans (cable.)
oem lsd
clutchet 6 puck clutch
exedy flywheel
Only problem is a 3rd gear grind. Was going to put new synchros in, but i decided to do something else.
3800.00
You will not find a lower mileage motor for that price alone. 600 miles, and it runs perfect. Motor was properly broken in, and is in great working order.
located in kalamazoo michigan.
Old Jul 25, 2006 | 03:45 PM
jaydmcrx's Avatar
Default Re: Jdm itr motor with ys1 cable trans forsale. (jaydmcrx)
redGSRguy
Northern California (Sales)
61
Jun 7, 2009 02:25 PM
jaydmcrx
Dec 7, 2005 06:45 PM
JIDUM_Undercover
May 17, 2005 04:43 AM
B2FiNiTY
Jul 5, 2004 07:23 PM
