ckp sensor wiring - read archives...
ok from what i understand c1 and c2 are going to the blue/green and blue/yellow wires coming out of the dizzy. what i dont understand is this: b10 is the crank angle sensor and b12 is also the crank angle sensor, but arent those already connected @ c1 and c2? to i wire them in series with c1 and c2? im very confused. right now im throwing a code 4.
Yeah i bileve the dpfi and mpfi ecu's have the crank angle in differnt locations on the ecu
c1 and c2 is the crank angle sensor location on the dpfi ecu, however on the mpfi ecu the crank angle sensor is located at pins b10 and b12. Hope this helps you out.
jdmdreamz414
Jul 22, 2011 06:08 AM
Lead_moose
22
Jun 7, 2010 02:11 PM
crxnonvtec
Aug 28, 2009 11:12 AM
