Piston Clearance
Old Apr 22, 2002 | 05:14 PM
BananaRepubliXo2's Avatar
Default Piston Clearance
Can someone tell me what i can safely set my skunk2 cam gears...... i am worried about the piston clearance against my valves with skunk2 stage 1 cams..... i have je 11:9:8 high compression pistons........ i tried to call je and they had had no idea (and nothing about the piston dome specs) and i called skunk2 and they said contact je and find out the piston dome specs..... does anyone know what i can do? im set at 0 right now and im running fine and the idle is around 1200 after a little settling, sometimes at 2000 after running it a while..... i have a skunk2 computer also.... much thanks in advance.... any advice will help
Old Apr 22, 2002 | 05:45 PM
riceboy's Avatar
Default Re: Piston Clearance (BananaRepubliXo2)
Call JE back and tell them to give you the piston dome specs, and find out the valve relief diameter and depth if you dont already know.
[Modified by riceboy, 2:45 AM 4/23/2002]
darrinbrewer
Mar 30, 2005 04:05 AM
drumking15
Jan 10, 2005 10:09 AM
datap1mp
Aug 4, 2004 10:41 AM
jdmcx
Jan 14, 2004 06:56 AM
