88 hf rear disc conversion
Old Jul 25, 2006 | 12:36 PM
mcabrera's Avatar
Default 88 hf rear disc conversion
whats up... new to hondatech, and was curious if anyone could help.
I recently got a rear trailing arm and disc conversion for my 88HF rex. My question bein will a 94 gsr teg set up work as well (not a 90-93) i was told on tamparacing forums 94 up setups would work as well. the member who told me is definitely a honda engineer but wanted to hear it twice so i came to you dudes. if they do work does any modifying or fabbin need to be done? anyone help would be appreciated.
Old Jul 25, 2006 | 12:42 PM
b.d.racing's Avatar
Default Re: 88 hf rear disc conversion (mcabrera)
Straight bolt in process
Old Jul 25, 2006 | 12:46 PM
EL Vap133's Avatar
Make sure you use your stock LCAs.
Old Jul 25, 2006 | 12:47 PM
mcabrera's Avatar
Default Re: 88 hf rear disc conversion (b.d.racing)
thats what i like to hear... thanks bro.. bump..
Old Jul 25, 2006 | 12:48 PM
mcabrera's Avatar
yah thats what i've hear, stock LCA's and uppers and 90-91 crx si lines... correct me if thats wrong...
Old Jul 25, 2006 | 01:20 PM
elecgenius's Avatar
i think you only need the proportioning valve so it can feed a different amount to the rear disk. *instead of the whole lines*
Old Jul 25, 2006 | 01:49 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcabrera &raquo;</TD></TR><TR><TD CLASS="quote">yah thats what i've hear, stock LCA's and uppers and 90-91 crx si lines... correct me if thats wrong...</TD></TR></TABLE>
Yes, you need 90-91 CRX Si brake lines for the rear.
mpaone
Jan 30, 2009 09:50 AM
thomas_mersereau
Oct 14, 2008 04:20 AM
pac_crx
Jul 15, 2006 05:53 PM
NsX_CrX
May 28, 2004 08:21 AM
