B16 CRX Engine light on w/serious wheel hop???? what gives??
Old Apr 22, 2002 | 05:10 PM
91~CRXSi's Avatar
New User
Default B16 CRX Engine light on w/serious wheel hop???? what gives??
If i dump the clutch and have a bad tire spin with wheel hop the check engine light will come on. First time this happened it cut the motor off for a split second and came right back on but ran kinda crappy until i cut the key off and back on. Then ran fine. SO i gave it another try and the check engine light comes on again but ran fine. Turn it off and back on and CEL is off. What gives????
Old Apr 22, 2002 | 05:15 PM
Jared's Avatar
Default Re: B16 CRX Engine light on w/serious wheel hop???? what gives?? (91~CRXSi)
how about you check the code before we try to guess what your problem is.
Old Apr 22, 2002 | 09:11 PM
SiR831's Avatar
Default Re: B16 CRX Engine light on w/serious wheel hop???? what gives?? (Jared)
what kind of clutch are you using?
Old Apr 22, 2002 | 09:55 PM
TRAY's Avatar
Did you do your swap?? On bolth my rex's I swapped the CEL would come on after a couple runs cuz I wired the O2 sensors together. If you didnt do your swap than thats prob whats happening. No big deal
Old Apr 22, 2002 | 10:18 PM
Brandon Chun's Avatar
Default Re: B16 CRX Engine light on w/serious wheel hop???? what gives?? (TrayDay2K1)
Yeah the code would be helpful.
Old Apr 22, 2002 | 10:22 PM
JALOP B16's Avatar
Default Re: B16 CRX Engine light on w/serious wheel hop???? what gives?? (Brandon Chun)
you got some loose wire some where when the car hops it is proably shaking the wire and that might be giving you a code
what code are you getting?
Old Apr 26, 2002 | 01:16 PM
EVOCELICA's Avatar
New User
Default Re: B16 CRX Engine light on w/serious wheel hop???? what gives?? (JALOP B16)
get some good struts and you'll stop the wheel hop
VtecAdil
Jun 3, 2005 04:47 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
UpstateCivic
Jun 7, 2003 12:27 PM
Yellow Dragon
Aug 5, 2001 01:04 PM
