OBD0 and OBD1 TPS's the same?
Old Jul 25, 2006 | 11:11 AM
brokenojoke's Avatar
Default OBD0 and OBD1 TPS's the same?
Reason I ask is I have 89 civic DX w/ hondata s200. I'm using an STR 65mm T/B w/ a stock OBD0 TPS.
At WOT I'm only reading 88% on my hondalogger, hence this question?
Old Jul 25, 2006 | 04:02 PM
zCivic's Avatar
Default Re: OBD0 and OBD1 TPS's the same? (brokenojoke)
There the same. I would say you need to adjust your TPS on the Throttle body, its prob sitting at negative voltage at closed throttle.
Old Jul 25, 2006 | 06:10 PM
Default Re: OBD0 and OBD1 TPS's the same? (zCivic)
At first it was, but then I adjusted it up to 0%. At first it was at -2%. I started the car, turned on my logger, then adjusted it to 0%. Turned off car and restarted, and the reading stayed at 0%.. WOT still = 88%.
I'm going to try to use an si tps instead of my DX one. I am supposed to able to use the DX one as well, but just have to switch two of the wires for it to read correctly. On the DX motor, the tps is backwards with the dual point injection. This is my understanding at least. It's been a while since I wired the car.
Percival123
Feb 3, 2015 05:09 PM
99teggsr
Aug 18, 2013 09:09 AM
trecool44
Nov 9, 2008 03:07 PM
