Problem with GF's DB8, windows wont go up or down, and mirrors wont move?
Old Jul 25, 2006 | 08:30 AM
jdm_bones's Avatar
Default Problem with GF's DB8, windows wont go up or down, and mirrors wont move?
GF drives tmy DB, and today she noticed that the mirrors and windows weren't working? Does anyone, know of a way to fix this? Any info would be good! Thanks HT...
Old Jul 25, 2006 | 08:45 AM
jdm_bones's Avatar
Default Re: Problem with GF's DB8, windows wont go up or down, and mirrors wont move? (jdm_bones)
everything is in tact, I pulled the door panel off to take a look...but I found nothing, is it a common thing for the windows and mirrors to just stop working...I myself had never had this problem with my DC...It's just very hot and annoying to not have working windows and mirrors!
Old Jul 25, 2006 | 08:49 AM
jdm_bones's Avatar
Maybe a fuse or something, I'll check that after work!
Old Jul 25, 2006 | 09:34 AM
rgaray's Avatar
Is it working on the other door switches? Check the fuses and the actual switch itself.
Old Jul 25, 2006 | 09:40 AM
lsvtek's Avatar
Default Re: (rgaray)
It has to be a fuse, if none of the windows or mirrors are not working it has to be a fuse or maybe a short
Old Jul 25, 2006 | 09:57 AM
jdm_bones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray &raquo;</TD></TR><TR><TD CLASS="quote">Is it working on the other door switches? Check the fuses and the actual switch itself.</TD></TR></TABLE>
I'll be checking the all fuses once I get off work! But after she told me, I checked it out and non of the switches to the windows were working, then I tried the mirror and they weren't either...So I was kind off scratching my head...I took off the door panel on the driveside and I found nothing, everything was in tact nothing burnt...I can't hear the motor moving when I am on the switch...
Old Jul 25, 2006 | 10:00 AM
jdm_bones's Avatar
Default Re: (4drlsintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drlsintegra &raquo;</TD></TR><TR><TD CLASS="quote">It has to be a fuse, if none of the windows or mirrors are not working it has to be a fuse or maybe a short</TD></TR></TABLE>
I am thinking in the same direction, I'll have to check them!
Old Jul 31, 2006 | 10:01 AM
rollndubsminusfive's Avatar
in mydb my bak window wouldnt go up one time and i found out it was this black coil spring that looks like a snail popped off and its hard to put bak because its hard to bend the metal dont use greese use ----spray will make it faster
shattachris
11
Mar 18, 2013 07:18 AM
datssoled
Jul 30, 2009 09:54 AM
JDMKid71
Jul 18, 2006 03:25 PM
typer464
Dec 3, 2001 04:33 AM
