Turbo help
Old Apr 22, 2002 | 04:31 PM
Brandon's Avatar
Life is Suffering
Default Turbo help
Which turbo kit should I get, I was thinking of an F-Max or Drag kit, but I can't decide (power vs. cost). Are there any others?
Old Apr 22, 2002 | 04:35 PM
H23 Power's Avatar
Default Re: Turbo help (vtec2k2)
omfg
1. you need to post what you drive
2. you need to search
3. you need to go to the forced induction forum...a little ways down the line...and search there also...
also, most people will just suggest making a custom kit
Old Apr 22, 2002 | 04:39 PM
Gennady's Avatar
New User
Se ello tu ma lil SAMMICH!!!!
Old Apr 22, 2002 | 05:32 PM
Nick H's Avatar
New User
Default Re: Turbo help (Wont be beat)
if you are deciding between the two go with the f-max...but i would definitely go custom...i think there's a kit sold online to make a custom turbo but i dunno where to get it...and yes...do search before the sammich war starts!
Old Apr 22, 2002 | 05:33 PM
acrdheadturner's Avatar
F-max... I have been looking into getting a trubo for a while.. you really should do some more searching its really clear which to go with after searching....
Old Apr 22, 2002 | 06:01 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Turbo help (acrdheadturner)
Go custom..
Old Apr 22, 2002 | 06:13 PM
LookingForVTEC's Avatar
Default Re: Turbo help (ForcedAccord)
Why would it be better to go custom over buying a kit??
Old Apr 22, 2002 | 06:24 PM
Texas B*tch!
Default Re: Turbo help (aopsunshine)
You can choose the parts/brands that you want.
You can use the sufficient fuel injectors, boost controller, turbo timer, etc.
Getting your pipes custom fitted assure the fact that they will fit and aren't a generic copy of someone elses "supposedly" same car. You always hear of things not matching up etc.
The wait for an FMAX is a pain in the ***, it takes a long, long time to receive it after ordered.
Go custom, get it built to your specs, and get it done right the first time
Old Apr 22, 2002 | 08:54 PM
Brandon's Avatar
Life is Suffering
Default Re: Turbo help (01GSR)
I may have been unclear, but I drive a 94 Accord EX with a manual. I definitely cannot go custom, as the costs will go through the roof. I am on a budget and I won't mind the wait, I've waited this long...
Old Apr 22, 2002 | 09:18 PM
Kazmans94cord's Avatar
Default Re: Turbo help (nickh2k1)
i know im late...but hey its all good...haha...
Old Apr 23, 2002 | 04:32 AM
Brandon's Avatar
Life is Suffering
Default Re: Turbo help (kazmans94cord)
I would have searched, but for some reason it refuses to work.
Old Apr 23, 2002 | 04:49 AM
Nick H's Avatar
New User
if you go custom it'll actually be cheaper than buying the f-max kit you speak of (that is if you can install it yourself...though this is the same with the f-max)...so the custom kit shouldn't be as expensive of a mod...but do some research on these products and then ask more specific questions....good luck!
Old Apr 23, 2002 | 09:45 AM
H23 Power's Avatar
yes, you can surely build a good kit for under $3500
INTEGLS96
Feb 18, 2004 12:55 PM
1stealthls
Mar 12, 2002 09:07 PM
Immortal23
Nov 21, 2001 10:54 PM
