Difference b/w JDM LS and USDM LS motors?
Old Jul 24, 2006 | 08:37 PM
J.nguyen's Avatar
Default Difference b/w JDM LS and USDM LS motors?
i know JDM LS motor is about .4 higher compression then USDM LS motor. so that means the PISTONS are different, but is everything else the same, ie fuel rail, intake manifold?, gaskets?, motor mounts, etc etc..
bout to swap in this JDM ls motor into my turbo charged setup and want to know all the details before actually doing it incase if i run into a problem.
Old Jul 25, 2006 | 01:38 PM
J.nguyen's Avatar
Default Re: Difference b/w JDM LS and USDM LS motors? (Jesse.)
Old Jul 25, 2006 | 05:19 PM
CubanLynx84's Avatar
what ecu are you going to run? watchout for when you take the car for the emissions, Jdm motors have a hard time pasing.
Old Jul 25, 2006 | 06:50 PM
J.nguyen's Avatar
Default Re: Difference b/w JDM LS and USDM LS motors? (CubanLynx84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CubanLynx84 &raquo;</TD></TR><TR><TD CLASS="quote">what ecu are you going to run? watchout for when you take the car for the emissions, Jdm motors have a hard time pasing.</TD></TR></TABLE>
im gonna run with my old ecu thats already tuned on chrome?? im not worried about smog right now, worried about gettin car up and runnin good.
Old Jul 25, 2006 | 06:52 PM
lVlemphizStylez's Avatar
the jdm motor claims like 5 hp more...
Old Jul 25, 2006 | 07:05 PM
J.nguyen's Avatar
Default Re: Difference b/w JDM LS and USDM LS motors? (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">the jdm motor claims like 5 hp more...</TD></TR></TABLE>
i already know that the JDM motor has diff comprssion pistons.. wondering what else is diff..
Old Jul 25, 2006 | 07:13 PM
well i have a jdm sir-G in my car...besides the pistons there werent that many differences between it and a usdm gsr...oh and my timing belt cover has japanese lettering on it
Old Jul 25, 2006 | 08:51 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">well i have a jdm sir-G in my car...besides the pistons there werent that many differences between it and a usdm gsr...oh and my timing belt cover has japanese lettering on it </TD></TR></TABLE>
ic.. so everything should be good..
Old Jul 25, 2006 | 09:57 PM
jdm_bones's Avatar
Intake Manifold is different, kind of looks like the old B16 IM...And is not legal, I think!
Old Jul 25, 2006 | 10:09 PM
trick_db's Avatar
everything should be the same. not much of a diff g. you still interested int eh stock b20 block? if so come down and check it out
Old Jul 26, 2006 | 12:02 PM
J.nguyen's Avatar
Default Re: Difference b/w JDM LS and USDM LS motors? (trick_db)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trick_db &raquo;</TD></TR><TR><TD CLASS="quote">everything should be the same. not much of a diff g. you still interested int eh stock b20 block? if so come down and check it out </TD></TR></TABLE>
na, dont wnat b20 no more.. too risky to turbo /w stock sleeves in long run..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Intake Manifold is different, kind of looks like the old B16 IM...And is not legal, I think!</TD></TR></TABLE>
ic... thats the kinda info i need / lookin for.. ittle diff stuff.. ie sensors? etc etc.
DrKelso
Aug 28, 2009 09:49 PM
eglslsd
May 17, 2007 04:59 PM
Justin Yoo
Sep 3, 2006 10:07 AM
Novtecdohc
Mar 9, 2006 07:02 PM
tobe1424
Sep 19, 2005 05:40 PM
