Adjusting trunk springs? Anybody done it?
I put an OEM spoiler on my car and I need to adjust the trunk springs so that it holds up the extra weight of the spoiler without falling down. There's two load settings on the springs, but I can't seem to get them to pop over into the other notch.
Does anybody know how to do it?
the oem wing should have came with stiffer tensioners.....
its a package deal when you buy the wing from the dealer..
EDIT: you need a special tool to R+R the tensioners...unless you find a weird way of doing it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i »</TD></TR><TR><TD CLASS="quote">the oem wing should have came with stiffer tensioners.....
EDIT: you need a special tool to R+R the tensioners...unless you find a weird way of doing it...</TD></TR></TABLE>
well the wing came from Japan with just the trunklid..I didn't get springs with it.
Do you have any clue what the tool looks like? If I knew what to do with them I could probably make something work.
yeah its a weird looking tool, i have one @ work i use...you can order one from honda or even snap-on i believe... i could possibly take a pic of it for you tomorrow if im not too busy.....
what car and year btw?
It's an '89 Civic sedan. if the tool isn't too expensive i'll just try to buy it. I tried for about 20 minutes with the trunk open and shut and I just couldn't get the springs to budge.
What would be involved in switching from a trunk lid with the OEM optional wing to one with no wing?
UNBRE4K4BLE
Honda Civic (2001 - 2005)
May 27, 2007 08:14 PM
