fog light wiring help, fusebox
Old Jul 24, 2006 | 01:17 PM
byronl's Avatar
Default fog light wiring help, fusebox
im in the middle of wiring up the foglights when i came upon this problem. Everything else went fine except for the part where you plug a connector into the fusebox. My problem is that I don't have this plug, i just have two wires...no plug.
I'm really a noob when it comes to wiring but what do i do?
i'm also following this guide
https://honda-tech.com/zerothread?id=1352749
Old Jul 24, 2006 | 02:57 PM
BlueIntegraBoy's Avatar
Default Re: fog light wiring help, fusebox (byronl)
Instead of a plug, you have a female spade connector (which acts as the plug).
Old Jul 24, 2006 | 03:13 PM
byronl's Avatar
Default Re: fog light wiring help, fusebox (BlueIntegraBoy)
ahh i c thx but now i have another problem haha. The spot where i connect the connector to is already used up, i'm pretty sure it's my alarm that's there....is there any other place i could connect it to or another solution?
Old Jul 24, 2006 | 03:38 PM
That spot is for fuse #19. Which means if you pop a fuse for the fog lights, you'll pop the fuse for the headlights (I think). Anyways, you'll need to cut some of the insulator off and cut off the female spade connector, and splice the two.
EG694Si
Nov 25, 2007 09:15 PM
5iveLugEK
Nov 23, 2005 08:41 AM
garstud
Jun 10, 2003 02:19 AM
