battery relocation, fire question
Old Jul 24, 2006 | 12:59 PM
GoFastTshirts.com's Avatar
Default battery relocation, fire question
i relocated my battery to the rear hatch. the battery box i got is bigger then my battery but it comes with this plastic flimsy divider. on the other side of the divider is dead space so i stuffed it with a towel so the battery can't push past the divider. is this safe ? i don't wanna cause a fire....
Old Jul 24, 2006 | 01:00 PM
CRX Toad's Avatar
Default Re: battery relocation, fire question (RexOwner)
Personally I think a block of wood might be a little better while it can still burn hopefully you would notice it a tad faster and be able to get it out. Do you know anyone that can fab up some metal brackets or anything in there that would be the best situation.
Old Jul 24, 2006 | 01:01 PM
yz125rider21's Avatar
no safer than a plastic box...lol...be fine unless acid spilled it just eat away at towel...but I suggest mounting it better in future...cause I have pieces of wood in mine
Old Jul 24, 2006 | 01:37 PM
APEX CRX's Avatar
I suggest adding an inline circuit breaker too just in case
Old Jul 24, 2006 | 02:15 PM
rsca_crx's Avatar
Default Re: battery relocation, fire question (APEX CRX)
make sure the box is strapped and mounted properly, because while you probably won't have the towel light on fire from the battery directly, a crash will likely rip the battery box off if is just bolted (since its plastic, and the actual battery is only held to the car with a "flimsy plastic divider and a towel"). flying batteries are bad- mount that thing securely.
for the spacer, get another piece of plastic to make a "T" or a "V" behind the flimsy peice, and rivet it to it. Now slip the whole thing in there and you should be good to go.
Old Jul 25, 2006 | 01:24 PM
Default Re: battery relocation, fire question (rsca_crx)
thanks guys i will try your suggestions, btw its an optima red top so at least its sealed
Highny
25
Apr 13, 2016 07:07 AM
HondaCRXnewbie
Feb 4, 2013 02:01 PM
ryanevansoh
Jun 30, 2009 12:24 AM
slow hatch
Feb 2, 2007 09:49 AM
Doctor CorteZ
Feb 13, 2003 08:04 AM
