One Thing After Another ... D@MN IT!
Old Jul 24, 2006 | 11:37 AM
Slomies's Avatar
Default One Thing After Another ... D@MN IT!
I'm doing an h23 head swap onto my f22 block and have all the parts to finally do it. well I started to take the head apart to replace the gasket and what not and one of the bolts snapped off in the head. ***profanity goes here*** what do you guys recommend that I do to get it out? take it to a shop or attempt to ezout it?
Old Jul 24, 2006 | 11:47 AM
MLBZ521's Avatar
Default Re: One Thing After Another ... D@MN IT! (95AccordVtec)
Happened to me.. And hated it..
^^Make that a few times..
If you feel compfortable drilling it out, do that and EZOut it..
Otherwise, I guess you'll have to take it to a shop..
OH! And be sure to get all new bolts for the head there, or you'll be going through this again... TRUST ME!
Old Jul 24, 2006 | 12:00 PM
92hondalude's Avatar
Default Re: One Thing After Another ... D@MN IT! (MLBZ521)
i did this a few times also...
dril it slowly and striate and ez out it
Old Jul 24, 2006 | 12:05 PM
BoostedH23Accord's Avatar
Default Re: One Thing After Another ... D@MN IT! (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">i did this a few times also...
dril it slowly and striate and ez out it </TD></TR></TABLE>
Took the words out ma mouf!
Old Jul 24, 2006 | 05:22 PM
Slomies's Avatar
alright i'll give that a shot. does arp make head studs for it?
do they make an ez out that long to get it?
Old Jul 24, 2006 | 06:22 PM
ayougo's Avatar
Default Re: (95AccordVtec)
actualy...ARP does make head studs for your application
Old Jul 24, 2006 | 08:55 PM
Slomies's Avatar
hell yea, def gonna pick those up since i dont want **** to break in the head again ...
EDIT: the head studs are what I want to replace the bolts that hold the cam caps in place, correct? which are the arp ones that bolt the head to the block?
Modified by 95AccordVtec at 1:06 AM 7/25/2006
Old Jul 24, 2006 | 11:28 PM
Rosko's Avatar
head studs are head studs which arent what you broke off.
however, arp will make anything you want for the right price, but all you should need is a little antisieze on them threads or even oil and you should be fine. just dont overtighten.
Old Jul 25, 2006 | 01:42 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
H23 ARP head studs are also what you use for the F22 block
just to add my 2 cents.....
Old Jul 25, 2006 | 05:58 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (I got the CD5 Jeebies!)
that sux! sorry to hear that and good luck man....keep us posted.
Old Jul 25, 2006 | 07:28 AM
1epmugenlude's Avatar
I would also try removing it yourself , just be careful and good luck!
Old Jul 25, 2006 | 08:43 AM
prelittlelude's Avatar
Default Re: (1epmugenlude)
good to see someone is making an H/f hybrid.. just try to ezout it, after that if no luck take to machine shoop. and arp does make head studs that bolt the block to head.. but i don't know about bolts for the cam caps.. you can ask them
Old Jul 25, 2006 | 11:24 AM
Slomies's Avatar
yeah i was inspired on here to make the h/f hybrid and want to finish it. i've run into so many problems though it's not even funny. this is head #2 and that bolt is the only thing holding me back. damn I just want to finish this ...
Old Jul 25, 2006 | 11:54 AM
dont give up, just be patient! good luck
Old Jul 25, 2006 | 12:38 PM
Slomies's Avatar
^^^^ exactly!!!! I'm going to go ahead and pick up a helicoil kit to use to fix it. I'm not going to be able to get an ez out waaaaaaaay down in there I dont think. lmk what you guys think ...
Atomic_EF9
Mar 29, 2011 11:51 AM
twocross
Feb 23, 2011 03:07 PM
hawaii_boi_808
Jun 14, 2008 05:27 AM
memorybox
Oct 21, 2006 09:02 PM
Day-DayC
May 18, 2006 08:51 PM
