Clutch Master cylinder?
Old Jul 24, 2006 | 09:18 AM
mugenspoongsr's Avatar
Default Clutch Master cylinder?
I have a 1994 integra gsr this clutch master cylinder is the oem one and will match right up right? http://replacement.autopartswa...=true The first one. I was just wondering how hard it is to replace should i bring it to a shop or can i do it at home. Even if im not doing it i would like to know what the mechanic has to do. Thanks Step by step instructions please
Old Jul 24, 2006 | 09:27 AM
lsvtek's Avatar
Default Re: Clutch Master cylinder? (mugenspoongsr)
It is very easy, I changed both master and slave cylinder on my integra and it was very easy. Then you will have to bleed it after install and i think the link you provided of the master cylinder will work for your gsr
Old Jul 24, 2006 | 09:53 AM
Default Re: Clutch Master cylinder? (4drlsintegra)
thanks can you give me step by step instructions? or know a link that tells you
Old Jul 24, 2006 | 10:28 AM
bshshondaman06's Avatar
to bleed the clutch
https://honda-tech.com/zerothread?id=479958
to remove the cmc
https://honda-tech.com/zerothread?id=1274249
searching ftw
dayaftertomorrow33
Nov 20, 2016 04:08 PM
Hyoriu
Apr 16, 2009 09:10 AM
acuracy r
Jul 13, 2005 06:15 AM
sunlei
Mar 18, 2004 08:36 PM
