Dead power locks.
Old Jul 24, 2006 | 09:08 AM
Frankie324's Avatar
Default Dead power locks.
I have a 94 Accord EX Sedan. Since I bought the car the all power locks are dead. I searched and all i find are the buzzing sound when the actuators go bad. I checked all the fuses. Any other suggestions?? I want to fix this.
Old Jul 24, 2006 | 09:13 AM
Intense3.2's Avatar
Default Re: Dead power locks. (Frankie324)
Time for new actuators, im having the same problem with my accord. They are notorious for "ghosts in the doors" I just dont know why the hell is has to BUZZZZZZZZZZZZZZZZZZZZZZZZZ so damn loud. Pisses me the (&)*&^(*&^ off!
Old Jul 24, 2006 | 09:49 AM
Frankie324's Avatar
Default Re: Dead power locks. (Intense2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Intense2.2 &raquo;</TD></TR><TR><TD CLASS="quote">Time for new actuators, im having the same problem with my accord. They are notorious for "ghosts in the doors" I just dont know why the hell is has to BUZZZZZZZZZZZZZZZZZZZZZZZZZ so damn loud. Pisses me the (&)*&^(*&^ off!</TD></TR></TABLE>
NOOOO. I said that I did a search and all I just find are posts about buzzing actuators. I know about that probelm.
Mine are dead, all 4 doors. No buzzing, no nothing. Even when I open with a key none of the other doors pop open. HELPPPPP
Old Jul 24, 2006 | 11:33 AM
Frankie324's Avatar
bump!
Old Jul 25, 2006 | 09:10 PM
Frankie324's Avatar
bump.
Old Jul 26, 2006 | 08:30 AM
Frankie324's Avatar
bump for help.
Old Jul 26, 2006 | 08:48 AM
philadd's Avatar
Have you tried the passenger side lock switch? When you lock (not unlock) the driver's door with the key, does it lock the other doors as well?
Old Jul 26, 2006 | 09:27 AM
Frankie324's Avatar
Default Re: Dead power locks. (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried the passenger side lock switch? When you lock (not unlock) the driver's door with the key, does it lock the other doors as well? </TD></TR></TABLE>
yeah i tried that. thanks for the response.... any other suggestions??
Old Jul 26, 2006 | 10:19 AM
philadd's Avatar
I'm going to assume that your answer to...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">When you lock (not unlock) the driver's door with the key, does it lock the other doors as well? </TD></TR></TABLE>
... is "no".
You need to check to make sure you are getting power and ground to the driver's actuator. If you have are, then the actuator is bad and you need to replace it. If you are not getting power and ground, then you need to check the wiring.
Old Jul 26, 2006 | 10:46 AM
Frankie324's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to assume that your answer to...
... is "no".
You need to check to make sure you are getting power and ground to the driver's actuator. If you have are, then the actuator is bad and you need to replace it. If you are not getting power and ground, then you need to check the wiring.</TD></TR></TABLE>
would this still be the case even if the passenger side does not work by itself??
Old Jul 26, 2006 | 02:20 PM
philadd's Avatar
This would be the case if none of your locks work. If only one lock does not work, you need to go to the door in question, and test the solenoid for that door...
dmeconitas
Apr 23, 2010 11:55 AM
honda_jeff
Dec 5, 2007 08:23 AM
forsaken787
May 15, 2006 06:53 PM
.BigSexy
Feb 28, 2005 10:17 AM
Dopey2004
Nov 5, 2004 03:24 PM
