Z6 75.5mm SRP's work in a 75.5mm A6/Z6 Mini-Me?
Old Jul 24, 2006 | 08:41 AM
AbitAvenger's Avatar
Default Z6 75.5mm SRP's work in a 75.5mm A6/Z6 Mini-Me?
Well, in every thread I post the question is in the title.
I've got a 75.5mm A6 block mated to a Z6 head and I just came across some 75.5mm Srp Pistons. They will be mated to eagle rods, stock length. Will the pistons be fine in there?
Old Jul 24, 2006 | 08:54 AM
dohcdelsol's Avatar
Default Re: Z6 75.5mm SRP's work in a 75.5mm A6/Z6 Mini-Me? (AbitAvenger)
so the cylinders are 75.5mm and the pistons are 75.5mm???
I would say, with a hone and proper ring gap it will work correctly. Im not 100% on this but im in the mist of a z6 block (75.0mm) and just bought Cp 75.5's and need to bore out my cylinders .020 over standard.
Old Jul 24, 2006 | 09:01 AM
Ignore the piston size, I shouldn't have mentioned it. I know the sizes of the block and whatnot. I just need to know if the Z6 SRP's will work in an A6 block.
It's all being professionally built so the piston/wall gap/ring gap will be in spec.
Old Jul 24, 2006 | 11:51 AM
bump
Old Jul 24, 2006 | 02:23 PM
Default Re: (AbitAvenger)
Old Jul 24, 2006 | 02:28 PM
RyanEJ8's Avatar
Yes will work fine.
Old Jul 24, 2006 | 02:29 PM
Default Re: (RyanEJ8)
thanks thats all i needed
singleslamman
Apr 10, 2008 05:24 PM
97grnrs
Apr 10, 2007 10:34 PM
buddy4002
Sep 11, 2006 01:44 PM
nonuthinnewb
Aug 30, 2006 12:44 PM
SLOAZZ95
15
Dec 10, 2003 09:25 PM
