DA Thin side moldings??
Old Jul 24, 2006 | 08:03 AM
1badda's Avatar
Default DA Thin side moldings??
Hey fellas got a problem. My boy was painting my car and try installing my passenger side molding which is a thin side from japan, and now has broked the clips? Where can i get some clips from?? Honda where i work at does not carry them. I would need to know where i can get some
Old Jul 24, 2006 | 08:09 AM
BlueIntegraBoy's Avatar
Default Re: DA Thin side moldings?? (streetaccord)
Has he tried to use the ones from your thick moldings?
Old Jul 24, 2006 | 08:33 AM
solid gsr's Avatar
Default Re: DA Thin side moldings?? (BlueIntegraBoy)
i agree they should work
Old Jul 24, 2006 | 01:45 PM
1badda's Avatar
Default Re: DA Thin side moldings?? (solid gsr)
The orginals ones are too thick and they stick to the molding. The ones i am talking bout twist and come off . the orginal ones are stuck to the moldings
Old Jul 24, 2006 | 01:54 PM
Rikter's Avatar
Ok so you work at honda and you can't figure this out on your own? I hope you don't work in the parts department there.
Make a friend with someone in parts. Ask them to look in their inventory for something like what you need or close to. Buy 1 and see if it will work.
If that does not work you are having to order a new one from Japan. This is what happens when you put JDM stuff on your car and you don't live there.
-Rik
crxaddikt
Jun 8, 2011 08:15 AM
1badda
Jul 27, 2006 09:18 AM
Teg44
Mar 25, 2003 05:32 PM
steveo97civic
Jan 13, 2003 07:29 AM
mikeSONICGSR
Dec 30, 2002 10:48 AM
