Will d16y7 injectors work in a b18b motor?
Old Jul 24, 2006 | 06:35 AM
Project_EK's Avatar
Default Will d16y7 injectors work in a b18b motor?
what up,
My injectors in my b18b are dirty, but i have a set from my d16y7 laying around. could i use them in the b18 safely??
thanks
Old Jul 24, 2006 | 06:39 AM
B16CRXT's Avatar
Default Re: Will d16y7 injectors work in a b18b motor? (EKhatch219)
yes. they are the same.
Old Jul 24, 2006 | 06:40 AM
Loserkidwac's Avatar
Are you running a resistor box? Are the injectors in your B18b stock from that motor(OBD1) or are they OBD0 injectors...for some reason I think you will need to run OBD0 injectors if you are OBD0 since they are peak and hold and the OBD1 and OBD2 are saturated (that maybe backwards) but can't speak from experience, so if you are OBD1 I say yes
Old Jul 24, 2006 | 06:42 AM
Project_EK's Avatar
both motor are 1999 OBDII motors, but i have a jumper harness to convert to OBD1..they should work right? and also do they have the same flow rate?
Project_EK's Avatar
damn i just realize i posted in the wrong place..
sik_tC
Dec 14, 2009 05:29 PM
rice_patrol
Nov 14, 2008 01:55 PM
Project_EK
11
Jul 24, 2006 02:41 PM
jameskersten1
10
Aug 26, 2003 06:40 AM
TurBoTeG
Jul 12, 2002 05:55 PM
