'88 si trans on '91 std
ok, i have a 91 std and an 88 si trans but ive heard 88s have different splines.anyone who knows for sure please tell me if this will work.
No. The number of teeth on the input spline is different on a 1991 vs a 1988 clutch disk. So your 1991 disk won't work. Also, the 1988 clutch disk is too small to work with the larger 1990-1991 flywheel and pressure plate (unless you convert to a 1988 flywheel and pressure plate, which is another option). So the simplest way to deal with this problem is to use a 1986-1989 Accord disk. The Accord disk has the same number of spline teeth as the 1988 disk, but the same diameter as the 1990-1991 disk.
90_EX_Civic
Mar 1, 2010 07:02 AM
agendadjs
Dec 8, 2007 04:56 PM
orido 1.6
Jun 6, 2004 12:45 AM
