A/c question
Old Jul 23, 2006 | 08:06 PM
Boostage's Avatar
Default A/c question
If you do a fresh motor swap, then put on the compressor and just fill it up with 2 cans of freon without vaccuming the system, what happens?
Old Jul 23, 2006 | 09:33 PM
.Kevin.'s Avatar
Default Re: A/c question (Boostage)
I have read on another forum that vaccuming the system is not needed. I do not know what COULD happen but as someone said they did it without vaccuming it.
Old Jul 24, 2006 | 07:21 AM
Boostage's Avatar
up
Old Jul 24, 2006 | 09:09 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
If you did not open the system by removing the compressor and or any lines or other AC components you are fine. Otherwise you are leaving moisture and other contaminants into the system and they will wreak havoc and destroy the system. When ever you open an AC system up you must replace any worn or damaged parts, always must replace the dryer, and have the system evacuated and vacume tested for 30 minutes to ensure there are no leaks and that all contaminants are removed from the system.
Old Jul 24, 2006 | 09:24 AM
Boostage's Avatar
Default Re: A/c question (Hondaman56)
Well im sure i have a leak. damnit. more money
Old Jul 24, 2006 | 09:25 AM
APCforthewin's Avatar
Of course it can be done w/o evacuating the system, ive always been told to evacuate the system everytime you add refrigerent. If you dont you are leaving moisture and compressor oil in the system which is usually already in those little cans you buy at advanced auto so you'll have too much in the system. recover, evacuate, charge and you'll have colder and longer AC.
TheCivicMafia
Jun 19, 2009 02:53 PM
redeg61987
13
Sep 19, 2006 06:39 PM
90da4dr
Aug 1, 2005 09:40 AM
