Oil in Spark plugs.
Old Jul 23, 2006 | 07:17 PM
D-rush08's Avatar
Default Oil in Spark plugs.
i took out my spark plug wires and i seen a lot of oil in there. do i need a new head gasket or just sum new seals?
Old Jul 23, 2006 | 07:27 PM
Skipster04's Avatar
Default Re: Oil in Spark plugs. (D-rush08)
you need a new valve cover gasket, 5 min. fix. be sure to clean the surfaces where the gaskets meet the head and valve cover. also while your at it id go ahead and replace the end cam seal too.
Old Jul 23, 2006 | 07:43 PM
Jose-aka-Pedro's Avatar
Default Re: Oil in Spark plugs. (Skipster04)
Yeah its the Valve Cover gasket,
As said by skip, 5 min fix.
The cam seal requires taking the cams out, or I did
and thats not a 5 min fix, Timing belt etc.... have to come off.
Just replace the vlave cover gasket It should be like $25-$30
Old Jul 23, 2006 | 08:51 PM
BOOSTED_JDM_DB8's Avatar
Default Re: Oil in Spark plugs. (Jose-aka-Pedro)
you need to change the spark plug tube seals
Old Jul 23, 2006 | 09:04 PM
EG8R's Avatar
Default Re: Oil in Spark plugs. (BOOSTED_JDM_DB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOOSTED_JDM_DB8 &raquo;</TD></TR><TR><TD CLASS="quote">you need to change the spark plug tube seals</TD></TR></TABLE>
thats what I was gonna say. The valve cover gasket is a different part...
Old Jul 23, 2006 | 10:18 PM
90runner157's Avatar
Default Re: Oil in Spark plugs. (skelly ed666)
get the fel pro kit, for 20 bucks you get the valve cover gaskets, plug tube seals, and the top bolt seals. dont mess with the cam seals, thats a bigger job, if it aint broken dont fix it.
Old Jul 24, 2006 | 07:32 AM
tomithy's Avatar
I kind of have the same problem. Do I need to do anything about the oil in there?
Old Jul 24, 2006 | 08:07 AM
rgaray's Avatar
syphon the oil out if you can, or try to stick a shop towel to soak up most of the oil.
Old Jul 24, 2006 | 08:18 AM
tomithy's Avatar
i don't have enough oil in there to have to syphon it out and I tried soaking up the oil already, but theres definitely still some left down there
Old Jul 24, 2006 | 12:59 PM
That comes with the Valve cover gasket kit..........................
Old Jul 24, 2006 | 01:01 PM
Default Re: (tomithy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">i don't have enough oil in there to have to syphon it out and I tried soaking up the oil already, but theres definitely still some left down there</TD></TR></TABLE>
What I did the other day when I found my tube full of water
I took single peices of paper towels,
And rolled them into really small rolled up paper towels,
then I took a long flat head and pushed it down around the spar plug,
it worked for me, try it out
Old Jul 24, 2006 | 09:34 PM
Default Re: (Jose-aka-Pedro)
if its just oil just pull the plugs let the oil drain into cylinder it will blow smoke for a min then its all gone. thats what i do. dont do it if its water tho,
lgharis
May 23, 2007 06:10 PM
HGZ
Feb 18, 2007 11:27 AM
loup05
Jan 28, 2006 05:30 PM
dkris42
Jan 8, 2005 02:33 PM
erikiksaz1
13
Oct 7, 2004 06:21 AM
