Gears Really hard to go in
Old Jul 23, 2006 | 07:16 PM
D-rush08's Avatar
Default Gears Really hard to go in
it feels like my clutch pulls good but my gear are hard to go in. do i need a new clutch?
Old Jul 23, 2006 | 07:34 PM
The_Ricky_Is's Avatar
Default Re: Gears Really hard to go in (D-rush08)
my brother had the same problem. his problem was the sycros (sp?) but it could be something else.
Old Jul 23, 2006 | 07:37 PM
CleanLikeJdm's Avatar
Hype-R Stalker
I'd say clutch, spring popped out, and mine was Horrible to get into gear.
Old Jul 23, 2006 | 07:39 PM
D-rush08's Avatar
Default Re: Gears Really hard to go in (The_Ricky_Is)
just in case its the sycros...how much would it be to fix??
Old Jul 23, 2006 | 09:37 PM
lsvtek's Avatar
that may not be it, my gears were hard to go in and it happend to be my master cylinder, i changed both master cylinder and slave cylinder for the cliutch, does your clutch go all the way to the floor and just hang? Feels loose?
Old Jul 23, 2006 | 10:19 PM
90runner157's Avatar
Default Re: Gears Really hard to go in (4drlsintegra)
before you do everything expensive, why not change the oil and use 10w40 or redline oil. that fixed mine.
Old Jul 24, 2006 | 12:24 AM
sujinX's Avatar
change the tranny fluid. take it to a honda dealer and have them change it. the honda mtf is really good. it fixed my gearing problem. im not sayin it'll fix urs but its worth a try.
Old Jul 24, 2006 | 01:36 AM
slowturbo's Avatar
i had the same prob and it was a spring broke
Old Jul 24, 2006 | 04:42 AM
numbnuts22715's Avatar
if you have to push the clutch in all the way to the floor then its a hydraulic problem and if you have to change gears at the top(barely pushing the clutch in at all) its a clutch problem.
It could be the master cylinder, you could have low fluid due to a leak of the slave cylinder or something.
Old Jul 24, 2006 | 11:57 AM
J-Coop84's Avatar
Default Re: (numbnuts22715)
I have the same problem with mine. haven't driven it in weeks.
Its gotten so bad that the car won't even go into gear once I start it. I'd have to put it in 1st and then start it. Once I do that the car automatically takes off.
also, I have a hard time changing gears. It feels like I have to use 2 hands just to shift. On top of all that the clutch sounds like I'm dragging metal on the concrete
so with that said... I have to change the:
slave cylinder
clutch master cylinder
new clutch
resurface the flywheel
Old Jul 24, 2006 | 01:23 PM
danny99si's Avatar
Default Re: (J-Coop84)
well see if you have air in the line, pump the pedal a couple times and see if ti gos in
Old Jul 24, 2006 | 02:26 PM
Electrodynamic's Avatar
I just tore my trans off of my block and one of the springs in my clutch was laying in the bottom of the cover. Two oposing springs were f*cked (one was out of the holder like I mentioned, and one was on its way out). The clutch and throw out bearing need replaced so that will be done tomorrow night or the night after. If you're not grinding into your gears, I wouldn't say synchro's quite yet.
Old Jul 24, 2006 | 02:37 PM
victorious1's Avatar
i would start with the cheap stuff first.
if its hydralic, you can try and bleed it.
change tranny fluid. with a little lucas.
it might even be a warped flywheel. thats my problem right now.
Old Jul 25, 2006 | 01:55 AM
sohc_coupe24's Avatar
Had simliar problems so i changed the tranny fluid and re-bled clutch...that worked for me...
Killer4Sho
Transmission & Drivetrain
Apr 12, 2014 04:35 AM
sipolt89
Dec 10, 2008 02:34 PM
92jdmhatch
Sep 10, 2007 08:38 PM
ludelvr
Aug 13, 2003 10:54 AM
